74 260Z
I was taking the rear rims off ,1 lug nut was super tight,snap.....
*How does the rear drum come off?Is there any bolts holding it on? how does the rear wheel stay on if there are no bolts holding it? ..Thanks
https://www.classiczcars.com/forums/topic/36431-broken-lug-nut/
Rear drum just comes off. There are no bolt.
MAKE SURE YOUR HAND BRAKE IS DOWN!
If it's stiff - Just turn it as you pull straight towards you.
Wait...What?
