July 14, 201014 yr comment_325364 i was just reading the manual and noticed that it said the floor temp light is ONLY on california models.. could this mean my car is a california car and if so does that mean i have extra smog crap on it vs it being a arizona car?like stuff i can cap off or remove and still pass emissionsIT also says that only california model cars came with a cat converter which mine has one..this is in fact the 78 280z model manualYours is a California car.And you're stuck with the Cat.CSV is the COLD START VALVE.Timing has to be right as a basis for everything else.Get a temp tag for the car. and lower your blood pressure a bit. Link to comment https://www.classiczcars.com/forums/topic/36461-help-need-to-pass-emissions-by-the-16th/?&page=4#findComment-325364 Share on other sites More sharing options...
July 14, 201014 yr Author comment_325370 i had a temp tag for the car. they only give out 30 day temps and a 3 day temp. the 30 day temp is up on the 16th.and im going to get the timing fixed, and the coolent temp sensor hasnt been replaced but i replaced the plug and wires. and i believe it works because when i unplug it the car idles high and real nice and smooth, but when i try to drive it like that it spits and spudders.if i plug it in, it idles low and rough but drives good.also what is a FSM Link to comment https://www.classiczcars.com/forums/topic/36461-help-need-to-pass-emissions-by-the-16th/?&page=4#findComment-325370 Share on other sites More sharing options...
July 14, 201014 yr comment_325379 FSM= Factory Service Manual Link to comment https://www.classiczcars.com/forums/topic/36461-help-need-to-pass-emissions-by-the-16th/?&page=4#findComment-325379 Share on other sites More sharing options...
July 14, 201014 yr comment_325386 i had a temp tag for the car. they only give out 30 day temps and a 3 day temp. the 30 day temp is up on the 16th.and im going to get the timing fixed, and the coolent temp sensor hasnt been replaced but i replaced the plug and wires. and i believe it works because when i unplug it the car idles high and real nice and smooth, but when i try to drive it like that it spits and spudders.if i plug it in, it idles low and rough but drives good.also what is a FSMYou need to run the tests as outlined in the FSM to find out which components in the EFI/emission control system(s) are working properly and which aren't. There is a functionality test for each component. There's really no getting around it. Until you do that, you're just guessing. Link to comment https://www.classiczcars.com/forums/topic/36461-help-need-to-pass-emissions-by-the-16th/?&page=4#findComment-325386 Share on other sites More sharing options...
July 14, 201014 yr Author comment_325394 oh i completely agree. this weekend ill be under the hood of that thing probably all day sat and sunday. Link to comment https://www.classiczcars.com/forums/topic/36461-help-need-to-pass-emissions-by-the-16th/?&page=4#findComment-325394 Share on other sites More sharing options...
July 14, 201014 yr comment_325396 I think the kid is catching on..... Link to comment https://www.classiczcars.com/forums/topic/36461-help-need-to-pass-emissions-by-the-16th/?&page=4#findComment-325396 Share on other sites More sharing options...
July 14, 201014 yr Author comment_325398 i try. i fill my head with so much facts and ideas i tend to overlook reality. sometimes you just got to slow down and relax to realize what you got to do. Link to comment https://www.classiczcars.com/forums/topic/36461-help-need-to-pass-emissions-by-the-16th/?&page=4#findComment-325398 Share on other sites More sharing options...
July 15, 201014 yr comment_325418 There are a few guys at Desert Datsun that could help. Join their club and post asking for help. Their a pretty good bunch when it comes to that.I can't diagnose crap Link to comment https://www.classiczcars.com/forums/topic/36461-help-need-to-pass-emissions-by-the-16th/?&page=4#findComment-325418 Share on other sites More sharing options...
July 16, 201014 yr Author comment_325622 vacume advance was stuck in advance mode regardless of vacume being suplied to it.this was the problem.Thanks for the troubleshooting ideas. Link to comment https://www.classiczcars.com/forums/topic/36461-help-need-to-pass-emissions-by-the-16th/?&page=4#findComment-325622 Share on other sites More sharing options...
July 16, 201014 yr comment_325637 Check to make sure the vacuum advance plate is functional.E Link to comment https://www.classiczcars.com/forums/topic/36461-help-need-to-pass-emissions-by-the-16th/?&page=4#findComment-325637 Share on other sites More sharing options...
July 16, 201014 yr Author comment_325653 Im definitely going to take the dizzy out today after work and make sure nothing in there is rusted or anything like that, and hopefully the vacume pod is in good shape, if not ill free it up and then it wont ever advance . Link to comment https://www.classiczcars.com/forums/topic/36461-help-need-to-pass-emissions-by-the-16th/?&page=4#findComment-325653 Share on other sites More sharing options...
July 16, 201014 yr Author comment_325654 There are a few guys at Desert Datsun that could help. Join their club and post asking for help. Their a pretty good bunch when it comes to that.I can't diagnose crapthanks for the referal to them, errin on their forum suggested to check the vacume advance by unplugging the vacume hose and drive it, if i dont notice any difference then my vacume advance could be stuck in advance mode. i did just that and noticed NO difference.so if anyone else has an issue like this that is definitely something easy to try. Link to comment https://www.classiczcars.com/forums/topic/36461-help-need-to-pass-emissions-by-the-16th/?&page=4#findComment-325654 Share on other sites More sharing options...
