The oil pressure sender on my 240z has already gone bad, so I'm replacing it soon, but I'm afraid it might break off inside the block when I attempt to loosen it. What's the best way to remove it? Should I do it when the block is hot or cold? And is there any type of sealant I should use when installing the new one?
