SOLD
Not running because it has 170,000 miles and is worn out.
Nothing broken, it just leaks and burns oil. Automatic Transmission works fine. Missing intake and fuel injection system(wireing harness with all connectors intact). Everything else is there including A/C which worked before it was parked. Tires are in good condition.
A few light rust spots on bottom of door and on Qtr panels. Floor panel are in great shape. Clear coat is coming off of Dark Gray paint. Hood is bent at nose and right rear has a dent between wheel arch and bumper.
Interior carpets in great shape. Seats bottoms are cracked real bad would need recovering, but backs are in good shape. Dash cracked down middle has dash cap on it in good shape. All glass in good shape. Rear Hatch is in great shape, no rust. Drivers side window crank missing, but the window will role up and down. Console in good condition.
$300 and it's yours. let me know if you want to take a look at it.
I also have a 71 240z with an IMSA body package on it in partial completion. I was planning on taking the motor out of the 280 and rebuild it to put in the 240. $1800
Thanks
David
https://www.classiczcars.com/forums/topic/3648-77-280z/#findComment-20163
  • 3 weeks later...
