Email logins are now active ×
Priorities?
Davey G
Here's a list of items I need to do to my '78 280Z. Help me decide which order to do them in:
A/C repair - needs evaporator valve (It is 95 degrees here and this is my daily driver)
Clutch - needs new slave cylinder, but just squeeking so far
Differential - slow leaking of fluid, needs new seals
RPM hold (?) - the device below the throttle body that hangs the rpms between shifts...not working causing tendency to stall and affecting gas mileage
Opinions?
I'd place the personal comfort item on hold until the reliability issues have been resolved.
Thanks Frank. Doug Bakke is working on it. I've decided to do all of it while he's got it in his shop already. The man just does good work.
