Posted July 16, 201014 yr comment_325542 The front freeze plug on the passenger side of the engine on my 240z has been leaking and we can't figure out why. 2 days ago we replaced it with a new brass one and used gasket sealer all around it. Today there is another drip of coolant that came out of it. Anyone know why the freeze plug would develop a drip leak? It doesn't seem possible that the plug could be leaking again considering that we put a good amount of gasket sealer around the edges of the new plug when we installed it. Link to comment https://www.classiczcars.com/forums/topic/36506-freeze-plug-leak/ Share on other sites More sharing options...
July 16, 201014 yr comment_325557 Have you examined closely, with a magnifying glass, the condition of the block? Link to comment https://www.classiczcars.com/forums/topic/36506-freeze-plug-leak/#findComment-325557 Share on other sites More sharing options...
July 16, 201014 yr Author comment_325581 I'll have to do that tomorrow. What exactly should i be looking for? The coolant leaks out of the bottom edge of the freeze plug, so i suppose their could be an imperfection in the block, but before the engine was rebuilt none of the freeze plugs ever leaked. If there is an imperfection in the freeze plug hole, then I would just have to use better sealant when installing another freeze plug, correct? Link to comment https://www.classiczcars.com/forums/topic/36506-freeze-plug-leak/#findComment-325581 Share on other sites More sharing options...
