Where does the ground wire get bolted to? It is the one that is attached to the fuel sender wiring bundle and goes through the rear of the hatch deck and down by the fuel tank?
I've already got my tank installed :stupid: and am having issues figuring out where it goes. No brake or tail lights till I figure this one out. I know I can bolt it to ground anywhere it will reach but I was looking for the correct location for an early 240.
Thanks,
John
https://www.classiczcars.com/forums/topic/36519-body-harness-grounding-point/
Its attached with a self tapping screw to the side of the frame rail above the tank back there, just beside the hole where the harness passes through the hatch floor. Bad news, you can't get to it with the tank in....
Thanks Jim. Looks like I'll be dropping the tank, again.
I received the evap tank a week or two ago. Sorry I didn't get back to you on that. Looks great and I got it installed without breaking off any of the nipples and no more dents!!!!
