Hood Vents
Pomorza
One thought I didn't see mentioned was to simply pop the hood
open into the half-latch position. This will greatly improve airflow
while underway, resulting not only in the removal of heat, but
also in lessening the pressure of air rushing in through the grille
by giving the air a much easier place to exit.
I would think that by lessening "wind resistance" or "drag," you
would also realize a small increase in fuel economy. Also, by
increasing the flow of air the entire engine bay should be cooler,
mainly while underway, but even at a standstill the rising hot
air would have a larger escape route.
Possibly the best of all, it doesn't cost one cent to do it (and
probably saves money in fuel economy). As an added benefit,
you can maintain the stock appearance of the car simply by
closing the hood. No risk of the hood lifting and flying off like
a glider into oncoming traffic; since it opens at the cowl, any
air flowing over it will help keep it down even if the half-latch
chooses not to.
FWIW,~Rick~
Edited by Kathy & Rick
Or cut the hood seal at the rear allowing air to come through with the hood shut.
chooses not to.
FWIW,~Rick~
