August 6, 201014 yr comment_327435 Hi Carlos and Randy,I had the same crumbly fusible link assembly problem on my '78. I couldn't find used blocks anywhere, although I didn't make a completely heroic effort of it. I ultimately switched to maxifuses after briefly considering automotive circuit breakers (which are pretty cool). It's all described here:http://www.classiczcars.com/forums/showthread.php?t=35588... with photos.I also did an alternator wire upgrade and headlight relay conversion while I was into the harness. Diagrams are in the above thread. Edited August 6, 201014 yr by FastWoman Link to comment https://www.classiczcars.com/forums/topic/36616-fusible-link-280z/?&page=2#findComment-327435 Share on other sites More sharing options...
