Posted July 28, 201014 yr comment_326671 Whats up guys a few weeks ago my temp gauge wasn't working. At first I thought I just had a bad connection so I cleaned all the plugs but still no luck. So them after I went ahead and check the water temp sensor and found this the loose cable seem to becoming from what I believe is the water temp switch but im not sure. If you look closely you will see 2 small green spots were looks like cables were coming out of. I was over on zcar.com and I came across this thread but on the pics I didn't see that screw that I have the arrow pointing at.car is a 76 280z http://www.zcar.com/forums/702926/280z-question-newb Edited July 29, 201014 yr by mota z Link to comment https://www.classiczcars.com/forums/topic/36629-is-this-the-water-temp-switch-pics/ Share on other sites More sharing options...
