August 2, 201014 yr comment_327006 Diseazd said: No problem OZ......you're human afterall! The harmonic is clockwise and the distributor is counterclockwise....makes you think doesn't it? Kind of like the the pin height on the L28 piston.....right? Cheers!Cheers my friend! :classic: Link to comment https://www.classiczcars.com/forums/topic/36650-timing-off-180-degrees-but-runs-decent/?&page=2#findComment-327006 Share on other sites More sharing options...
August 2, 201014 yr comment_327007 Johnny said: Yeah' date=' no problem. There is always contradictory information in threads that's is why I go through as many as I can before I make a decision on a repair.Thanks for all the input. I haven't messed with the dizzy advance yet. I balanced the carbs after getting the timing straight yesterday and I am now idling at about 1100 rpms. I think if I tweak the timing I should be able to get it down to around 800.John[/quote']Can I just catch you on that last thought John.If your idling now at 1100rpm with the timing right, don't undo your work by backing off the timing....this is counterintuitive.What you need to do is adjust your idle speed via the idle speed screws to drop it down to 800 or so rpm. Keep your new timing as it is.Maybe that's what you meant, I'm just not sure by the way you worded it.Cheers. Link to comment https://www.classiczcars.com/forums/topic/36650-timing-off-180-degrees-but-runs-decent/?&page=2#findComment-327007 Share on other sites More sharing options...
August 2, 201014 yr Author comment_327022 Yeah, I thought my thinking was off a little. When I balanced the carbs I couldn't get the airflow to sync when I backed down the idle screws. My unisyn wouldn't even float when it was backed down below 1000 rpms. I adjusted the flow meter all the way in to create more of a venturi affect but it did not help.I think I need to buy a new flow meter. Mine is about 25 years old an a little beat up.I will get one from MSA and give it another go next weekend.Thanks for the tip. Link to comment https://www.classiczcars.com/forums/topic/36650-timing-off-180-degrees-but-runs-decent/?&page=2#findComment-327022 Share on other sites More sharing options...
