nice plate
I picked it up at a swap meet back when I thought the car I would be restoring was a 73, but alas it too far gone to restore. I will have to find a 70 plate.
Nice job. Good to see another alberta z. What bodyshop did you use?
I took it here. They are based in Wetaskiwin and I was told they do work for the Reynolds-Alberta Museum. The owner Randi did the paint.
Historic Restorations for all your restoration needs
Years ago my fan clutch locked up on my 71. It sounded like an airplane prop and robbed the engine of a lot of horsepower. My solution at that time was a flex fan. I drove the car for close to twenty years with it on and had no issues with it. Not original but a good solution. I likely still have the original steel fan if anyone is interested. Also, I'm going to be dissasembling my early 71 if anyone needs parts. Dan is using my old ashtray in his project. Glad to see it going to a good home.
Mark in Portland
Installed one of my homemade firewall insulators. As well the tunnel vinyl is in.
What material did you use to make your firewall insulator? I need to make some also.
I used a heavy rubber mat with a foam backing, it is a bit on the thick side and was hard to fit in places. I bought it at Princess Auto which is a lot like a Harbor Freight here in Canada. As well here is the Drivers side all done.
