Progress on rust repairs
240dkw
  • 1 year later...
 When the clutch locked up with a metal fan on my 71. The engine sounded like it had a aircraft prop. under the hood. It also robbed the engine of a bunch of power but no flying things. I'm not a big fan :) of the original clutch. I've never found two that spin alike.There was a noticeable difference when I took mine off. The engine revved quicker.
 If I remember correctly, Carl was referring to metal flex-fans self destructing. When my original fan clutch seized, I replaced it with a metal flex-fan and ran it hard for another 15+ years with no problem. Maybe I got lucky.The f-fans decrease parasitic HP loss because they flatten at speed and don't pull any air. The cooling system doesn't need a fan If the car is moving over 10-15mph.
