Still to rich???
segdoh
What happened to checking the wires by the coil? You said it wouldn't start when you screwed around bundling the wires-I would think that you found your problem there. Did you check for bare wires?
The electric fuel pump is probably not the issue-unless that's what you were running on, and your not. I have seen it happen many times where a bare hot wire gets hot and is close enough to metal it would ground out, you need to get on top of your car and look at the wiring with a microscope!
Steve,sorry I left that info out.Igot that wire prob.all squared away.I didnt mean to make it sound like the electric fuel pump was shorting out or part of the elec.problem.The reason I was checking out my fuel lines was because of my fuel smell.Thats when I found the fuel pump.I was reading that Datsun wa s using an electric fuel pump along with a mechanical one to stop a vapor lock problem.For some reason in my mind I am thinking that I may have a fuel pressure problem or a vapor lock problem.I can run my car balls out up to 110 120 mph.out in the country/rural with no problems.But in town stop and go traffic 35-45 mph.Its like it is loading up,popping, sputtering.Is this a fuel problem?
How hot was it when you had this problem? The early cars are known to have vapor lock issues, even when running, in hot weather, which is said to be the reason that Nissan added the electric pumps.
You would not see the problem on the open road, because the higher airflow at speed keeps the engine bay cooler.
Search for threads on vapor lock for more information.
Edit: Also search for threads on fuel smell. That is a common problem as well.
Edited by Walter Moore
Forgot something.
No fpr.what should the presure be?It goes straight from the pump to the metal tube that is hooked to the valve cover.It feeds both carbs,then a u turn back towards the pump.Not into the pump, but past it,and down to a metal line along the frame.The one clear looking tube is coming from the radiator over flow.And yes,it has been crazy hot here.
OK,so more to add to the list. Check thermo,and battery voltage at idle.Im not sure what that has to do with my problem,but you guys know more about this than me.I will log it in my memory bank/write it down....Thanx
It's a matter of checking the basics. If your voltage regulator is not maintaing voltage, your spark might be weak at idle, causing a unclean burn. You have a hot ignition that needs good battery voltage. To cold of an engine will also create issues of a rich mixture. A lot of times the problems are caused by basic elements not being correct.
I agree that checking basics is the place to start, but running down electrical problems when the carbs haven't been fully explored is a bit of a reach.
It is entirely possible that the electrical problem noted above is coincidental and not causal. But you wont know for sure until "the basics" are checked and confirmed.
Start at the beginning, not the middle.
gary,
I respectfully disagree. I think the carbs are one the last things to trouble shoot. All the basics should be covered before diving into the carbs. Why do I say that, because most other items are more straight foward to check then carbs. A simple voltage check eliminates many things. The carb function relies on so many engine functions that I have learned from past experiences, unless your sure, don't start with the carbs.
By theway Gary, I was born and raised in Moorestown NJ, but don't miss it:)
I wouldn't miss Moorestown either :) I live in the NW part of the state where the roads are twisty and people are few-and-far in between.
To beat this to death (something I enjoy), to me the basics are fuel, compression & spark - in that order. First I check if each is present, then I check the amount and timing.
  • Who's Online   0 Members, 0 Anonymous, 700 Guests (See full list)
