Posted August 12, 201014 yr comment_327742 Hi - I'm relatively new to the z world with a 72 240Z. My problem is dirt in one carb - the one closest to firewall. I'm sure there was dirt from tank that got past / through the filter. I've read a number of threads and will probably need to start by cleaning the tank and working my way to the carbs. A few questions: Can lines be cleaned (rather than replaced)? Is there a reason why only one carb is plugging up? Does fuel pump need to be cleaned? Any helpful hints?Thanks, Mike Link to comment https://www.classiczcars.com/forums/topic/36749-debris-in-carb/ Share on other sites More sharing options...
August 12, 201014 yr comment_327748 So Mike in Northern Ontario, welcome.What does this dirt look like? Color, consistancy?Our JUST SUs dvd would be a big help in taking you thru those carbs.What does the fuel filter look like? Probably the first thing I'd do is take the gas line off the float bowl and douche all the dirt out, put the gas line back on and drive the car to see how fast dirt might find it's way back into the float bowl. Throw a new filter on while you're at it. Link to comment https://www.classiczcars.com/forums/topic/36749-debris-in-carb/#findComment-327748 Share on other sites More sharing options...
August 12, 201014 yr Author comment_327749 Hi Bruce - dirt looks like black specs. First thing I did was clean carb. Drove the car as you suggested. Dirt build up happened quickly. Cleaned it again (third time) - this time left fuel line to carb detached and let some gas into container - more tiny black specs from line. New filter arrives today but concerned that it won't fix problem - seems like a fair amount of dirt. Also ordered a second filter and thinking of installing it at the tank. Link to comment https://www.classiczcars.com/forums/topic/36749-debris-in-carb/#findComment-327749 Share on other sites More sharing options...
August 12, 201014 yr comment_327756 You probably want to search on rusty gas tanks! You could have rubber lines or fuel pump deteriorating.You can use an air compressor to blow out the metal fuel lines.You can never have enough filters. Link to comment https://www.classiczcars.com/forums/topic/36749-debris-in-carb/#findComment-327756 Share on other sites More sharing options...
August 12, 201014 yr comment_327770 If you put the black specs between your thumb and forefinger does it smear around like maybe degraded rubber might or is it hard and gritty? Old gas line being attacked by something in our new hotrod crappy gas would be well up on my list of suspects. Replace the rubber lines in the engine compartment, about a $4 deal and see what you have. Link to comment https://www.classiczcars.com/forums/topic/36749-debris-in-carb/#findComment-327770 Share on other sites More sharing options...
August 12, 201014 yr Author comment_327771 Thanks - will replace the filter and have a closer look at gas lines and black specs. I'm hoping you're both right - it makes sense that the old lines could break down. It will be interesting to see if tank is NOT the problem. I'll try to get to this by weekend and let you know results - thanks again! Link to comment https://www.classiczcars.com/forums/topic/36749-debris-in-carb/#findComment-327771 Share on other sites More sharing options...
August 12, 201014 yr comment_327773 Again, is your filter showing anything that might be this black stuff? I find it hard to believe that if the black stuff is being replenished pretty fast after cleaning out the float bowls AND it's coming from upstream of your filter, the filter would be cluttered with the black stuff, if not clear full. Also, in the float bowl lids inside that humpy thing is a fine wire mesh screen filter. You might check that too for crappolla. Really curious to see the consistancy of the "stuff".... Really have to wait for the weekend? Can't take a couple of days off work just to satisfy our curiousity? Nyuck nyuck Link to comment https://www.classiczcars.com/forums/topic/36749-debris-in-carb/#findComment-327773 Share on other sites More sharing options...
August 13, 201014 yr comment_327872 Sounds very much like a problem I had.The filter wasclean but black specks kept appearing in the rear carby.Installed new rubber fuel lines and haven't had the problem since.Rick. Link to comment https://www.classiczcars.com/forums/topic/36749-debris-in-carb/#findComment-327872 Share on other sites More sharing options...
August 15, 201014 yr Author comment_328026 Took off the fuel filter - it was full. Black specs were hard and gritty. I changed the filter and cleaned the carb. It seems to be running fairly well. I'll have to remove and clean the tank but hoping this can wait until it's time to put the car away for winter. Am also going to replace fuel lines to carb when tank is cleaned. And, I now have two spare filters....Thanks for all of the advice - very helpful! Link to comment https://www.classiczcars.com/forums/topic/36749-debris-in-carb/#findComment-328026 Share on other sites More sharing options...
August 15, 201014 yr comment_328032 With this situation in mind I noticed that on Horsepower TV, just now, they were doing some re plumbing around a gas tank and replaced some rubber line with a gas line with a lining to resist degradation from our new gas. I'm thinking there is some unpublisized sculldugery going on with our current crop of fuel.......Opinions?? Link to comment https://www.classiczcars.com/forums/topic/36749-debris-in-carb/#findComment-328032 Share on other sites More sharing options...
August 15, 201014 yr comment_328044 I think you're right, Bruce, and here's why.I had driven the Z to Nashville Superspeedway on Saturday to watch a bit of the autoX action and found myself low on gas. Returning to the hotel, I ventured off the freeway into Smyrna and found a station totally by accident that sold gas without methanol. It was a bit spendier than the normal ethanol mix, but WOW, what a difference it made in how the Z ran. This stuff they're putting in our tanks is terrible! And "winter" gas isn't much, if any, better. Link to comment https://www.classiczcars.com/forums/topic/36749-debris-in-carb/#findComment-328044 Share on other sites More sharing options...
August 15, 201014 yr comment_328048 The real kicker would be to get MPG figures one fuel to the other also.On a trip to southern California back when Oregon still had real gas and CA didn't, my mileage suffered a 20% drop the minute I had to take on CA oxygenated crap. Oh, but for the good on the farm economy and the environment we need to burn 20% more of this stuff to get the same amount of work done. Doesn't compute in my feeble brain pan..... Link to comment https://www.classiczcars.com/forums/topic/36749-debris-in-carb/#findComment-328048 Share on other sites More sharing options...
