Posted August 13, 201014 yr comment_327900 I installed the MSA Short Shifter and it works fine but I wonder why the shifter knob is that heavy. It seems that the knob is an original Nissan part 32865-35F00. Can you tell me what the advantage of a relativly heavyweight knob is compared to a light one ? Link to comment https://www.classiczcars.com/forums/topic/36764-shif/ Share on other sites More sharing options...
August 13, 201014 yr Author comment_327901 I installed the MSA Short Shifter and it works fine but I wonder why the shifter knob is that heavy. It seems that the knob is an original Nissan part 32865-35F00. Can you tell me what the advantage of a relativly heavyweight knob is compared to a light one ? Link to comment https://www.classiczcars.com/forums/topic/36764-shif/#findComment-327901 Share on other sites More sharing options...
August 13, 201014 yr comment_327902 Realistically very little, and the very small penalty for the extra weight probably outweighs the even smaller benefit to shifting. I think the idea is that the heavier knob gives you more leverage on the stick so requires less effort to actually push the shift ring over the synchro and onto the gear cluster.After trying to use an actual 8 ball in a Z, I can tell you that a heavy shift knob will also vibrate and make noise if the shifter bushings are even very slightly loose, where a standard weight knob won't. Link to comment https://www.classiczcars.com/forums/topic/36764-shif/#findComment-327902 Share on other sites More sharing options...
August 13, 201014 yr comment_327911 Works as a mass damper. Reduces perceived vibration. Link to comment https://www.classiczcars.com/forums/topic/36764-shif/#findComment-327911 Share on other sites More sharing options...
August 13, 201014 yr comment_327915 Merged the pair of identical threads. Link to comment https://www.classiczcars.com/forums/topic/36764-shif/#findComment-327915 Share on other sites More sharing options...
August 14, 201014 yr comment_327927 Will the stock knob fit the MSA shifter? Link to comment https://www.classiczcars.com/forums/topic/36764-shif/#findComment-327927 Share on other sites More sharing options...
