Posted August 18, 201014 yr comment_328333 hey guys,If I were to improve performance of my 240z, what would be some good stepping stones to put down on paper (or this thread) to maybe get a third gear chirp on the road so to speak?original L24 motor, 5-spd trans 10/71 mnfctr datecan we form a priority list for what to buy/install/ do to the motor?thanks...B Link to comment https://www.classiczcars.com/forums/topic/36820-building-up-your-l24-wishlist-creation-help/ Share on other sites More sharing options...
August 18, 201014 yr comment_328339 Motor: Camshaft that will provide a 3500 - 6500 power band. Tuned SU or triple Weber/ Mikuni carbs. Headers. Ignition upgrade. <== These are starting points, not the end-all, be-all. Other: R200 3.9 or 4.11 diff. Hot asphalt. Link to comment https://www.classiczcars.com/forums/topic/36820-building-up-your-l24-wishlist-creation-help/#findComment-328339 Share on other sites More sharing options...
August 18, 201014 yr comment_328341 You know your going to hear" SEARCH", so I will be the first to say it. With 55 posts you should know how this works. I am also going for HP on my l24, but it's a road that is determined by cost and research. I have more money in my motor then i care to admit, but have no big numbers to brag about. I have poured over these Z sites and have the book on "how to modify..." and still know very little of all the options. TUNE TUNE TUNE-first, then go from there. Get a base line using a dyno or drag strip, and see if you are actually improving things as you go. do you want a fast DD or a week-end warrior? do you want to stay NA or turbo? I wanted a fast DD, something to take across country to the Z shows and also take it to do some autocrossing too. The L24 is a great motor, but much more money to modify then a chevy v-8, but that's not my cup of tea. I am shooting for 200hp at the rear wheels, more then enough for a fast car, but i have already done all the basic work(brakes, suspension,ect...) to start with.Good luck and keep those L24's going! Link to comment https://www.classiczcars.com/forums/topic/36820-building-up-your-l24-wishlist-creation-help/#findComment-328341 Share on other sites More sharing options...
August 18, 201014 yr comment_328342 This Quote Other: R200 3.9 or 4.11 diff. Hot asphalt. or If you were near Houston I'd consider selling my L24 that already has the cam, Webers, ignition, adjustable cam gear, header, and a 2.5" Mandrel bent exhaust :classic: Link to comment https://www.classiczcars.com/forums/topic/36820-building-up-your-l24-wishlist-creation-help/#findComment-328342 Share on other sites More sharing options...
August 18, 201014 yr comment_328343 Hey frank,did you ever dyno your car again, and was the car really running that rich when you dynoed at ZCON? Many members on the sites here have questioned the validity of my dyno graph. Link to comment https://www.classiczcars.com/forums/topic/36820-building-up-your-l24-wishlist-creation-help/#findComment-328343 Share on other sites More sharing options...
August 18, 201014 yr comment_328345 No, I haven't, Steve. I gotta get those Mikunis jetted before another dyno run. And yes, the dyno crew's tailpipe sniffer only went as low as 9.4 and I was richer than that. Phew! Stinky rich. The best run I got was 131 HP @ 6700. I know the car, properly tuned, is capable of roughly 180 HP, possibly more. It takes more than 131 to get to 135 mph, and it's been there-done that. Link to comment https://www.classiczcars.com/forums/topic/36820-building-up-your-l24-wishlist-creation-help/#findComment-328345 Share on other sites More sharing options...
August 18, 201014 yr Author comment_328346 ahhh yes, i remember back in HighSchool talk about putting a Maxima? cam in the l28s?...thanks for the input fellas.... I went through the tech tips but did not use a key word search for "engine mods" "improve performance" Link to comment https://www.classiczcars.com/forums/topic/36820-building-up-your-l24-wishlist-creation-help/#findComment-328346 Share on other sites More sharing options...
August 18, 201014 yr Author comment_328347 Mikez73 said: This or If you were near Houston I'd consider selling my L24 that already has the cam, Webers, ignition, adjustable cam gear, header, and a 2.5" Mandrel bent exhaust :classic: I've got a truck but no hoist... Link to comment https://www.classiczcars.com/forums/topic/36820-building-up-your-l24-wishlist-creation-help/#findComment-328347 Share on other sites More sharing options...
August 18, 201014 yr Author comment_328348 d240zx2 said: Motor: Camshaft that will provide a 3500 - 6500 power band. Tuned SU or triple Weber/ Mikuni carbs. Headers. Ignition upgrade. <== These are starting points, not the end-all, be-all.Other: R200 3.9 or 4.11 diff. Hot asphalt. as far as carbs goes.... I should have an air filter for them up here in the volcanic dusty Flagstaff area? Link to comment https://www.classiczcars.com/forums/topic/36820-building-up-your-l24-wishlist-creation-help/#findComment-328348 Share on other sites More sharing options...
August 18, 201014 yr comment_328349 bounce said: ahhh yes, i remember back in HighSchool talk about putting a Maxima? cam in the l28s?...The Maxima, at least the RWD Maxima, had an L24E. I had a 79 810 (same motor) for 6 years as a daily driver. The cam wasn't anything special. Link to comment https://www.classiczcars.com/forums/topic/36820-building-up-your-l24-wishlist-creation-help/#findComment-328349 Share on other sites More sharing options...
August 19, 201014 yr comment_328361 bounce said: as far as carbs goes.... I should have an air filter for them up here in the volcanic dusty Flagstaff area? You should always have air filters. Real air filters too...not those metal grate things. My filters have been off for pics and they are off right now because I still need to sync the carbs but I have the horns blocked off to keep out bugs I'd never run an engine without filters except while syncing the carbs. BTW I have a hoist but no truck . Link to comment https://www.classiczcars.com/forums/topic/36820-building-up-your-l24-wishlist-creation-help/#findComment-328361 Share on other sites More sharing options...
August 19, 201014 yr comment_328373 Are you looking to rebuild? If you want to rebuild--you may want to talk with Dave at Rebello--although their website does not mention it--they 'refresh' a lot of L24 motors. He claims that he can get 180 out of an L24 without going the 2.7 ITS motor route. http://www.rebelloracing.com/index.htmYou might also want to take a look at the November 2007 issue of Classic Motorsports--they did a L24 rebuild. A condensed version is still on their webite at http://classicmotorsports.net/project-cars/1970-datsun-240z/datsun-recieves-new-heart/ Link to comment https://www.classiczcars.com/forums/topic/36820-building-up-your-l24-wishlist-creation-help/#findComment-328373 Share on other sites More sharing options...
