Posted August 23, 201014 yr comment_328672 My 16 year old daughter just bought two Z's. The 79 to drive and the 83 for parts. I'm a restoration veteran but never on an older Datsun. It has set up for a couple of years but the previous owner was using it as a daily driver when he parked it. Other than getting some fresh fuel into it what should I look for to get it going? Link to comment https://www.classiczcars.com/forums/topic/36858-here-we-go/ Share on other sites More sharing options...
August 23, 201014 yr comment_328673 Welcome to the club. You came to the right place. Lots of threads on "waking the sleeping beast" A couple of years really isnt that long of a time compared to most around here. First you need the FSM which might be available here: www.xenons30.com then I would change all the fluids and filters(dont forget the fuel pump screen/filter), pull the plugs and try to crank the engine over with a wrench. I think its a 22mm on the older Z's, not sure about the 79 and newer.If she turns freely I would leave the plug wires off and crank it a little bit to get oil moving around the top end. After that put the plug wires back on and keep your fingers crossed.Good luck.John Link to comment https://www.classiczcars.com/forums/topic/36858-here-we-go/#findComment-328673 Share on other sites More sharing options...
August 23, 201014 yr Author comment_328674 Thanks John. I still have to get the car(s) home first though. I need tires. Then I plan to rent a tow dolly. Link to comment https://www.classiczcars.com/forums/topic/36858-here-we-go/#findComment-328674 Share on other sites More sharing options...
August 26, 201014 yr Author comment_329040 What are the differences between the 78 and 79? I found the 78 FSM Link to comment https://www.classiczcars.com/forums/topic/36858-here-we-go/#findComment-329040 Share on other sites More sharing options...
August 26, 201014 yr comment_329043 I dont know the details but there are many. First of all they are 2 different body styles. The last year of the S30 was 78. Try www.zhome.com. They answer a lot of questions there.John Link to comment https://www.classiczcars.com/forums/topic/36858-here-we-go/#findComment-329043 Share on other sites More sharing options...
August 31, 201014 yr comment_329616 What are the differences between the 78 and 79? I found the 78 FSMThe link that John gave is for S30's. Since your car is a 280ZX (S130), you need to look here for the 79 FSM: http://xenons130.com/reference.html Link to comment https://www.classiczcars.com/forums/topic/36858-here-we-go/#findComment-329616 Share on other sites More sharing options...
August 31, 201014 yr comment_329626 The link that John gave is for S30's. Since your car is a 280ZX (S130), you need to look here for the 79 FSM: http://xenons130.com/reference.htmlThanks Stephen. I need to work on my reading comprehension.:stupid: Link to comment https://www.classiczcars.com/forums/topic/36858-here-we-go/#findComment-329626 Share on other sites More sharing options...
September 1, 201014 yr comment_329716 the fact that you are going to be hooking up your daughter is awesome. Link to comment https://www.classiczcars.com/forums/topic/36858-here-we-go/#findComment-329716 Share on other sites More sharing options...
