My 16 year old daughter just bought two Z's. The 79 to drive and the 83 for parts. I'm a restoration veteran but never on an older Datsun. It has set up for a couple of years but the previous owner was using it as a daily driver when he parked it. Other than getting some fresh fuel into it what should I look for to get it going?
https://www.classiczcars.com/forums/topic/36858-here-we-go/
Welcome to the club. You came to the right place. Lots of threads on "waking the sleeping beast" A couple of years really isnt that long of a time compared to most around here.
First you need the FSM which might be available here: www.xenons30.com then I would change all the fluids and filters(dont forget the fuel pump screen/filter), pull the plugs and try to crank the engine over with a wrench. I think its a 22mm on the older Z's, not sure about the 79 and newer.
If she turns freely I would leave the plug wires off and crank it a little bit to get oil moving around the top end. After that put the plug wires back on and keep your fingers crossed.
Good luck.
John
