Yep, I guess the carb is contributing to the instant black on a new set of 3 plugs. Were it a bad set of rings in one hole, one plug would be black not all three. They call it super sleuthing..... nyuck nyuck
ok round two compression readings are:
1 105
2 100
3 100
4 100
5 105
6 100
I stood at the throttle linkages while warming her up and revved up to maybe 4500 or so.... some blackish smoke comes out
Edited by bounce
One other thing, I was able to find a service manual for my 77 Z on the web. It will have all of the specs and should help you troubleshoot also. So look for one for yours.
Edited by bergermiester
1 105
2 100
3 100
4 100
5 105
6 100
The numbers seem low, but they are very even across the board, which is good. The lowness could be as simple as a low-reading gauge.
that's good news....
there is a nice crack in the glass lense of the comp tester gauge....
I agree that the gauge could be suspect. Your readings on #1 and #6 were higher the first time you did it when the engine was cold and the throttle was closed. This does not make sense, I'm guessing your numbers are actually higher than you are measuring.
