Posted August 27, 201014 yr comment_329152 Hi guys,New member to the site and unfortunately coming along with a problem!Just before Christmas 09, I managed to fulfill my dream of owning a Z car, a 1978 260Z 2+2 (UK spec). I drove it from the UK back to Ireland with absolutely no problems and everything was fine for a few months (apart from a battery drain problem and a 30 second long starting procedure!).Unfortunately the car has develped some problems which I need a bit of help on as I'm at the point of frustration!The engine is misfiring and I have a voltage regulator related battery drain!If anyone could help with these problems it would be greatly appreciated!http://www.classiczcars.com/forums/showthread.php?p=337321http://www.classiczcars.com/forums/showthread.php?p=337322Thanks!Mark Link to comment https://www.classiczcars.com/forums/topic/36902-hello-from-ireland/ Share on other sites More sharing options...
August 27, 201014 yr comment_329153 Possibly your alternator is faulty. Even tho you might be getting a charge at the battery a bad alternator can drain it. Link to comment https://www.classiczcars.com/forums/topic/36902-hello-from-ireland/#findComment-329153 Share on other sites More sharing options...
