Email logins are now active ×
Early Transmission question
I'm going back to the early transmission style and as I was prepping it in anticipation of getting my engine re-installed (throw out bearing, collar,lever and assorted springs) I noticed that the later dust boot is way too large to re-use.
My question is , are there any other differences I need to be aware of, like flywheel bushing sizes or anything else that might make me crazy that I can deal with now while its on the bench.
Thanks All,
H Houghton
I can't think of much else different, Hugh. The pilot bushings are all the same. As I'm sure you are aware, the release bearing collar has to match the pressure plate, and the clutch fork and slave cylinder will also need to match. But the rest should be all the same.
