Email logins are now active ×
reverse lights don't work
raltz
2 red with black stripe wires. Follow them from the lower firewall (the engine harness) back toward the tranny. They have open bullet connectors on them. The switch is on the passenger side of the tranny and around the middle.
Already covered it. Those are the reverse light wires. PO obviously messed up. Test them as stated above and go from there.
thank you everyone, i did attach the red cables to the switch and the reverse lights work...THANK YOU THANK YOU THANK YOU!!!!
but as for the neutral switch i don't see anything else on the transmission that looks like the reverse switch by the shifter...so i still don't know where the mystery green wires go, but thank you guys for your help
  • Who's Online   1 Member, 0 Anonymous, 164 Guests (See full list)
