Posted August 31, 201014 yr comment_329586 i just purchased my 1973 240z last friday, i noticed my fuel guage didn't work (previous post asking for help with that) but i still need to drive it home, i went to get gas first and fill it up, but when i was filling it, the gas pump kept going and the fuel seem to be overflowing from the top of the tank...it was like watch you dump money down the drain..does anyone know why the pump just wouldn't stop when full, and what i would need to check and repair so that next time i go to fill up it doesn't overflow like thatThank you Link to comment https://www.classiczcars.com/forums/topic/36946-fuel-overflows/ Share on other sites More sharing options...
August 31, 201014 yr comment_329594 Perhaps its a faulty gas pump. It pays to watch the thing when filling. The pipe that goes from the cap to the tank is often rotten allowing gas to escape if you fill the tank to the top. If the fuel was poring out underneath then there would be no surge up the filler pipe to activate the mechanism to switch off the gas pump. Edited August 31, 201014 yr by olzed Link to comment https://www.classiczcars.com/forums/topic/36946-fuel-overflows/#findComment-329594 Share on other sites More sharing options...
August 31, 201014 yr comment_329646 Are you saying that the fuel came out of the pipe where the pump hose went in, or somewhere else? On my '73 the pipe is larger than those on newer cars and does not seal real well at the hose. I have to manually hold the hose pressed to the pipe until the pump first kicks off (i.e. I don't click the handle down for automatic feed). Link to comment https://www.classiczcars.com/forums/topic/36946-fuel-overflows/#findComment-329646 Share on other sites More sharing options...
August 31, 201014 yr Author comment_329659 thanks guys, it looked like it was leaking from the the top of the tank, it wasn't over flowing from where the gas goes in, i didn't get the initial click that it was full, i just started hearing a loud dripping sound and looked underneath and the gas looked to be overflowing from the top Link to comment https://www.classiczcars.com/forums/topic/36946-fuel-overflows/#findComment-329659 Share on other sites More sharing options...
September 1, 201014 yr comment_329694 Probably not the top of the tank, but one of the vent hoses. (there are three)Two are near the seam, about mid way up, and I think that there is one near the top of the tank. All three are hidden by body panels. You have to pull the tank to replace them.Search the site for vent hoses or something like that and you will get an idea of what you are in for. Link to comment https://www.classiczcars.com/forums/topic/36946-fuel-overflows/#findComment-329694 Share on other sites More sharing options...
September 14, 201014 yr Author comment_330817 thanks everybody!! Link to comment https://www.classiczcars.com/forums/topic/36946-fuel-overflows/#findComment-330817 Share on other sites More sharing options...
September 14, 201014 yr comment_330821 I'm no expert but, on my 73 the filler tube to tank is just a rubber tube with hose clamp that attaches to gas tank. I would check to see that is still in place and fitted correctly over bib that comes off tank. Its tricky to reach from right rear fender well after removing the inspection panel that is held by 4-5 screws. Link to comment https://www.classiczcars.com/forums/topic/36946-fuel-overflows/#findComment-330821 Share on other sites More sharing options...
September 15, 201014 yr comment_330851 And don't forget the breather hoses......I am so tempted to remove the fuel fuel vapor control soluition and just pollute the environment a little bit..... Maybe drive fasterJay Not just a Z - ZDisease Link to comment https://www.classiczcars.com/forums/topic/36946-fuel-overflows/#findComment-330851 Share on other sites More sharing options...
