Posted September 2, 201014 yr comment_329778 Brand new cap, rotor, points, condensor and coil.Still run rough only at idle very peppy and responsive otherwise.Weak fire on cylinder #4 at idle when wire unplugged. Wires changed 03/09 with Napa Blue BMX (about 14K ago).My feeling is the #4 spark plug wire is the problem. The engine was running smooth a couple of weeks ago and it happens only at idle as missing intermittently on one cylinder.What do you think? Link to comment https://www.classiczcars.com/forums/topic/36969-240z-rough-idle/ Share on other sites More sharing options...
September 2, 201014 yr comment_329790 Weak spark, valve burnt , rocker adjusted too tight, bad spark plug. Get a compression test done might tell you. My 2c worth. Link to comment https://www.classiczcars.com/forums/topic/36969-240z-rough-idle/#findComment-329790 Share on other sites More sharing options...
September 5, 201014 yr Author comment_329974 Weak spark, valve burnt , rocker adjusted too tight, bad spark plug. Get a compression test done might tell you. My 2c worth.If you tried to scary me. It was just fine tuning carb adjustment and balancing after tune-up and timing advance. Link to comment https://www.classiczcars.com/forums/topic/36969-240z-rough-idle/#findComment-329974 Share on other sites More sharing options...
