Wire I.D. please
7T1240
I thought is was only hot when the key is in those positions and the Fan switch was in one of the 3 speeds but no power if in the off position (fan speed switch) Please correct me if I'm wrong.
Then the blue connects to the Dealer installed AC switch and out to the A/C wire on the left side, under the coil area.
Right or wrong. going by memory here.
Dave
I just checked that wire with this new info because I was wondering what it was for. On my 240 that wire agrees with Zs-ondabrain and is hot in ACC and ignition but only when the fan is on. I am trying to label all the wires under the dash as I have left overs from a POs wiring though everything seems to be working.
