Posted September 7, 201014 yr comment_330138 Hi allThree months ago I did an oil change in my Z. I decided to run a lower weight oil (10W40) as, well it was on sale. In the past (I'm sure you guys might remember) I had a rather interesting noise coming from the top end. Well after this oil change I ran a can of seafoam through the intake and the noise all but disappeared. This evening I did another oil change. I went back to the 20W50 oil I've used in the past as 104 degree summers do nice things engines here. Well the noise is back. Same marble sounds when I release the throttle. Usually appears around 3K or so and lasts until idle. The cam itself is rather loud now. I don't understand why oil weight has this affect on my car. I ran a tad bit of sea foam through the intake but it didn't solve any of the issues. Does anyone have ANY ideas what this can be? It is driving me nuts when I rev and I hear that BLASTED rattle. It scares me. The chain and tensioner are new, BRAND new. The valves are all adjusted the right way. I've checked and rechecked and rechecked. ThanksJan Link to comment https://www.classiczcars.com/forums/topic/37012-this-baffles-me-to-no-end/ Share on other sites More sharing options...
September 7, 201014 yr comment_330139 How long has it been since the engine was last rebuilt? Is there any risk that you have sludge in your oil passages? Thinner oil will naturally flow better through restricted passages. Link to comment https://www.classiczcars.com/forums/topic/37012-this-baffles-me-to-no-end/#findComment-330139 Share on other sites More sharing options...
September 7, 201014 yr Author comment_330162 How long has it been since the engine was last rebuilt? Is there any risk that you have sludge in your oil passages? Thinner oil will naturally flow better through restricted passages.I don't see sludge being in the oil passages as I've run two different desluging agents in the engine. I've inspected the cam and all the oiling holes look good. When the car is running (with valve cover off) there is equal amounts of oil coming from the cam oiling holes. Jan Link to comment https://www.classiczcars.com/forums/topic/37012-this-baffles-me-to-no-end/#findComment-330162 Share on other sites More sharing options...
September 7, 201014 yr comment_330164 My inexperience in Arizona/desert heat is going to be apparent here, but why not go back to the lighter weight oil? Some high quality oil would probably work nicely right? Link to comment https://www.classiczcars.com/forums/topic/37012-this-baffles-me-to-no-end/#findComment-330164 Share on other sites More sharing options...
September 7, 201014 yr comment_330165 I don't see sludge being in the oil passages as I've run two different desluging agents in the engine. I've inspected the cam and all the oiling holes look good. When the car is running (with valve cover off) there is equal amounts of oil coming from the cam oiling holes. JanSome sludge and carbon buildup in engines can be bad enough that those solvents have no effect on the buildup. You have obviously inspected the oil flow but perhaps it's restricted enough somewhere that it's affecting oil flow at higher rpm? Pure speculation obviously, just thinking out loud. Link to comment https://www.classiczcars.com/forums/topic/37012-this-baffles-me-to-no-end/#findComment-330165 Share on other sites More sharing options...
September 7, 201014 yr comment_330168 With all this modern internet technology around............ I know, why don't you post a high quality video/audio of your noise? Diagnosis can be easier if we can see/hear the 'patient' Just a thought. Good luck with it. Link to comment https://www.classiczcars.com/forums/topic/37012-this-baffles-me-to-no-end/#findComment-330168 Share on other sites More sharing options...
September 7, 201014 yr Author comment_330184 With all this modern internet technology around............ I know, why don't you post a high quality video/audio of your noise?Diagnosis can be easier if we can see/hear the 'patient' Just a thought. Good luck with it. I get your point. I'll try to get a video up later this week if I can find the time. Jan Link to comment https://www.classiczcars.com/forums/topic/37012-this-baffles-me-to-no-end/#findComment-330184 Share on other sites More sharing options...
September 7, 201014 yr comment_330189 My inexperience in Arizona/desert heat is going to be apparent here, but why not go back to the lighter weight oil? Some high quality oil would probably work nicely right? Because the FSM calls for 20/50. Link to comment https://www.classiczcars.com/forums/topic/37012-this-baffles-me-to-no-end/#findComment-330189 Share on other sites More sharing options...
September 7, 201014 yr comment_330199 Because the FSM calls for 20/50.Look again. I ran 10W-40 in my Z and 810 the entire time I had them. The only wieght the FSM doesn't recommend is 5W-20 for sustained high speed driving. Link to comment https://www.classiczcars.com/forums/topic/37012-this-baffles-me-to-no-end/#findComment-330199 Share on other sites More sharing options...
September 7, 201014 yr comment_330202 Sorry,Steve-YOU look again.I am looking at both FSMs(as i type this),one for the 810 and one for the 78 620 and they both call for 20/50 for temperatures encountered here in Tucson.And as a side note they also call for 140 weight gear lube. Link to comment https://www.classiczcars.com/forums/topic/37012-this-baffles-me-to-no-end/#findComment-330202 Share on other sites More sharing options...
September 7, 201014 yr comment_330207 Okay, I looked again an again I saw the same thing I saw before and every other time I've looked at it. The charts are the same in both FSMs. What am I missing? Edited September 7, 201014 yr by sblake01 Link to comment https://www.classiczcars.com/forums/topic/37012-this-baffles-me-to-no-end/#findComment-330207 Share on other sites More sharing options...
September 7, 201014 yr comment_330208 Think about how the oil pump is driven and that might lead to to a clue as why different weight oil could cause a noise. Thicker oil is harder to pump. Check that the harmonic balancer is tight.Steve Edited September 7, 201014 yr by doradox Correct spelling Link to comment https://www.classiczcars.com/forums/topic/37012-this-baffles-me-to-no-end/#findComment-330208 Share on other sites More sharing options...
