Need to replace this switch. The ones I get have 2 tits coming out the front and the switch is too big to to fit in were the old one came out. The one I am trying to replace has 2 wire coming out of the switch and the inside is concaved. Does anyone have one for sale or know where I can find on
https://www.classiczcars.com/forums/topic/37013-75-280z-engine-fan-switch/
That sounds like the water temperature switch what the 75 and 76 had. Has nothing to do with the engine fan as the fan is mechanical not electrical. I believe it's function was to operate the EGR solenoid. It might be a tough find as they're no longer in stock through Nissan as per a thread a couple years back. 22120-N4202 is the part number if that's of any help. If you search that number I'm sure a few threads on the subject will come up.
