Posted September 11, 201014 yr comment_330573 Hello Everyone,I am searching for a couple of working F.I.C.D. Magnet Valves from a '77 - '78 Z. These are the two electric solenoids that are mounted on the passengers fender well near the Fusible Links/Relays. One is for the fast Idle when the AC is on, the other feeds vacuum to the dash.Apparently one of mine has seized up and has stopped working. I would really appreciate it if any of you could hook me up! Please PM me!BTW - You can tell if you have a good one by passing 12v across the plug - Blue being Positive and Black being Negative. The valve will have a noticeable, hardy click.Thanks to everyone in advance! :classic: Link to comment https://www.classiczcars.com/forums/topic/37060-i-need-some-working-ficd-magnet-valves/ Share on other sites More sharing options...
September 12, 201014 yr comment_330644 FAIW, one of mine is seized up too, and it's not really a problem. The one that feeds vacuum to the dash can be bypassed without any negative consequences. It's redundant with the vacuum selector switch (mode switch), as I recall. The other does actually have a function, of course. That said, if you set your idle just a touch higher than normal (maybe 100 RPM), your engine will be happy dragging the compressor even without the help of the fast idle actuator. My car's previous owner didn't have the fast idle anywhere near to correct adjustment, and it didn't actuate. Even so, the engine ran fine with the compressor. I fixed it and properly adjusted it, and honestly the engine could almost do without the thing. Link to comment https://www.classiczcars.com/forums/topic/37060-i-need-some-working-ficd-magnet-valves/#findComment-330644 Share on other sites More sharing options...
September 13, 201014 yr Author comment_330717 FAIW, one of mine is seized up too, and it's not really a problem. The one that feeds vacuum to the dash can be bypassed without any negative consequences. It's redundant with the vacuum selector switch (mode switch), as I recall. The other does actually have a function, of course. That said, if you set your idle just a touch higher than normal (maybe 100 RPM), your engine will be happy dragging the compressor even without the help of the fast idle actuator. My car's previous owner didn't have the fast idle anywhere near to correct adjustment, and it didn't actuate. Even so, the engine ran fine with the compressor. I fixed it and properly adjusted it, and honestly the engine could almost do without the thing.Thanks for the info, but I think that I am going to see if I can round one up. I always thought that valve setup was kooky - there are more elegant ways to kick the idle up a bit. Bosch engineers should have electronically increased the idle via the EFI. Ahh woulda, coulda, shoulda. Link to comment https://www.classiczcars.com/forums/topic/37060-i-need-some-working-ficd-magnet-valves/#findComment-330717 Share on other sites More sharing options...
September 13, 201014 yr comment_330742 Well, if you find a source/solution, let me know. If it doesn't cost a fortune, I might be interested in replacing mine too, just to have it original. Link to comment https://www.classiczcars.com/forums/topic/37060-i-need-some-working-ficd-magnet-valves/#findComment-330742 Share on other sites More sharing options...
September 15, 201014 yr comment_330886 I'm sure you have already thought of this, but most likely place to find this part is in a salvage yard. Places like Pick and Pull have a battery you could test the part before purchase or if not they will refund your money if it does not work. I have an extra set I took off a salvage 1977 Z and I'll use your testing suggestion to see if they are good. The previous owner of my car had bypassed these and it did fine. Link to comment https://www.classiczcars.com/forums/topic/37060-i-need-some-working-ficd-magnet-valves/#findComment-330886 Share on other sites More sharing options...
September 15, 201014 yr comment_330898 I also connect my vacuum gun to them when testing. They should hold vacuum when closed and allow vacuum to pass through when under power. For testing purposes I carry a 9 volt battery with me. For switches, solenoids, etc. that will provide more than enough power plus I don't have to look for the junkyard's test battery. Edited September 15, 201014 yr by sblake01 Link to comment https://www.classiczcars.com/forums/topic/37060-i-need-some-working-ficd-magnet-valves/#findComment-330898 Share on other sites More sharing options...
September 16, 201014 yr Author comment_330998 I'm sure you have already thought of this, but most likely place to find this part is in a salvage yard. Places like Pick and Pull have a battery you could test the part before purchase or if not they will refund your money if it does not work. I have an extra set I took off a salvage 1977 Z and I'll use your testing suggestion to see if they are good. The previous owner of my car had bypassed these and it did fine.I found a working pair in my parts collection, but I am still interested in your extra set if you are willing to part with them. Let me know. Thanks Edited September 16, 201014 yr by ZCurves Link to comment https://www.classiczcars.com/forums/topic/37060-i-need-some-working-ficd-magnet-valves/#findComment-330998 Share on other sites More sharing options...
September 16, 201014 yr Author comment_330999 I also connect my vacuum gun to them when testing. They should hold vacuum when closed and allow vacuum to pass through when under power. For testing purposes I carry a 9 volt battery with me. For switches, solenoids, etc. that will provide more than enough power plus I don't have to look for the junkyard's test battery.That is a cool trick for testing in the field. 9 volts is enough to see if they are good or not. Thanks for the tip! Link to comment https://www.classiczcars.com/forums/topic/37060-i-need-some-working-ficd-magnet-valves/#findComment-330999 Share on other sites More sharing options...
