Posted September 12, 201014 yr comment_330678 Does anyone have experience with using the aluminum offset rear bushings after lowering their car? Are they necessary? Does the camber need to be adjusted? I am lowering my car with the Tokico/Lumina kit.My car is a 1970 ZMike Edited September 12, 201014 yr by mbarjbar Link to comment https://www.classiczcars.com/forums/topic/37078-camber-adjusting-rear-bushings/ Share on other sites More sharing options...
September 13, 201014 yr comment_330714 Yes, no, no. They work fine, they're not absolutely necessary, and lowering a Z generally results in a lot more neg camber in the rear than the front. Link to comment https://www.classiczcars.com/forums/topic/37078-camber-adjusting-rear-bushings/#findComment-330714 Share on other sites More sharing options...
September 13, 201014 yr Author comment_330720 Thanks. Any idea how much negative camber results from lowering with the kit I mentioned? I guess increased inside tire wear is an issue.Mike Link to comment https://www.classiczcars.com/forums/topic/37078-camber-adjusting-rear-bushings/#findComment-330720 Share on other sites More sharing options...
September 13, 201014 yr comment_330724 I have them on the front and rear of my '71 that is lowered with the BRE springs. I have not had any issues with tire wear with them. At the time I put them on it was recommended to avoid the excessive negative camber. 1 degree negative front and 3/4 degree negative in the rear (1/2 to 3/4 was the recommendation). Link to comment https://www.classiczcars.com/forums/topic/37078-camber-adjusting-rear-bushings/#findComment-330724 Share on other sites More sharing options...
September 13, 201014 yr comment_330733 Thanks. Any idea how much negative camber results from lowering with the kit I mentioned? I guess increased inside tire wear is an issue.No, but I'm sure there are quite a few people with that setup who can answer. Link to comment https://www.classiczcars.com/forums/topic/37078-camber-adjusting-rear-bushings/#findComment-330733 Share on other sites More sharing options...
