Does anyone have experience with using the aluminum offset rear bushings after lowering their car? Are they necessary? Does the camber need to be adjusted? I am lowering my car with the Tokico/Lumina kit.
My car is a 1970 Z
Mike
Edited by mbarjbar
Yes, no, no.
They work fine, they're not absolutely necessary, and lowering a Z generally results in a lot more neg camber in the rear than the front.
I have them on the front and rear of my '71 that is lowered with the BRE springs. I have not had any issues with tire wear with them. At the time I put them on it was recommended to avoid the excessive negative camber. 1 degree negative front and 3/4 degree negative in the rear (1/2 to 3/4 was the recommendation).
Thanks. Any idea how much negative camber results from lowering with the kit I mentioned? I guess increased inside tire wear is an issue.
No, but I'm sure there are quite a few people with that setup who can answer.
