Hello Everyone,
I originally posted this in the other forum, but thought that I would give it a shot on this side of the house. I am searching for a couple of working F.I.C.D. Magnet Valves. My car is a '78 Z and I am pretty sure that these were used on ZX, 810 and Maximas that had the L28. The F.I.C.D. valves are the two electric solenoids that actuate the vacuum for the fast Idle when the AC is on, the other feeds vacuum to the dash.
Apparently one of mine has seized up and has stopped working. I would really appreciate it if any of you could hook me up! Please PM me!
BTW - You can tell if you have a good one by passing 12v across the plug - Blue being Positive and Black being Negative. The valve will have a noticeable, hardy click.
Thanks to everyone in advance!:classic:
The ones used on the 280Z are different from the ones used on the ZX, 810, et al. I've owned all three. The ones on the Z are taller and thinner, joined together by a common plug and in a metal bracket while the others are shorter and larger in diameter and screw into the top of the vacuum tank. You can pretty much only use the ones for a Z on a Z. They're not interchangable without a fair bit of fabrication.......
