Posted September 14, 201014 yr comment_330802 My headlight lenses on my wife’s car are real dull & cloudy. I thought about replacing them but now I see that there are some restoration kits available. Has anybody tried anything like this? Does it really work? Here’s a couple I was looking at:http://www.autobodytoolmart.com/3m-headlight-lens-restoration-system-39008-p-16386.aspxhttp://www.autobodytoolmart.com/symtech-bright-solutions-headlamp-polishing-car-care-kit-75010010-p-16214.aspxThanks Link to comment https://www.classiczcars.com/forums/topic/37094-headlight-lens-repair-question/ Share on other sites More sharing options...
September 14, 201014 yr comment_330803 I have used inexpensive products found at an auto parts chain store and from Harbor Freight tools. Both kits had the different abrasives used with wet sanding, and both resulted in marked improvement in the amount of light that passed through the lenses.Caveats:If water has leaked inside the headlight or there is oxidation inside, you'll need to clean up the inside of the lens, too.The cheaper kits may not have anything to "preserve" the lens. I don't know what coatings (if any) manufacturers use on headlight lenses, and I don't know if the sanding processes remove any protection. The cars I polished the lenses on were not mine, and I have not had any opportunity to observe long-term changes.Suggestion:Cover the car surfaces near the headlight with painters tape or some other similar material. It is easy to brush those surfaces during the polishing process and scuff them.Steve Link to comment https://www.classiczcars.com/forums/topic/37094-headlight-lens-repair-question/#findComment-330803 Share on other sites More sharing options...
September 14, 201014 yr comment_330805 I've used the rubbing compound type of headlight restoration kit. It worked well. I didn't use a buffing pad on a power drill, just a rag and elbow grease.Dennis Link to comment https://www.classiczcars.com/forums/topic/37094-headlight-lens-repair-question/#findComment-330805 Share on other sites More sharing options...
September 14, 201014 yr comment_330810 Different lenses respond differently. I've used rubbing compound on my Lexus and they cleaned up pretty well. A friend has tried wet sanding and then polishing his BMW lenses and they still look like crap. Whatever you do, its probably a good idea to keep wax on them after polishing. This not only fills in the small pits, creating a clearer surface, but also retards (can I still say that word?) future oxidation. Link to comment https://www.classiczcars.com/forums/topic/37094-headlight-lens-repair-question/#findComment-330810 Share on other sites More sharing options...
September 14, 201014 yr comment_330813 Depending on the amount of UV rays the lenses have received, the yellowing haze could be simple oxidation WITHIN the plastic that no amount of sanding will remove (unless you sand THROUGH the lens).Clear plastic doesn't have the UV stabilizers found in other plastics (few as that may be). As a result it's more prone to cracking and yellowing. Older plastic formulations were specially prone to this, newer ones seem to last a bit longer.FWIWE Link to comment https://www.classiczcars.com/forums/topic/37094-headlight-lens-repair-question/#findComment-330813 Share on other sites More sharing options...
September 14, 201014 yr comment_330828 I've used the 3M kit on two cars with very good results. No swirl marks when it was done and the lenses were clear. Link to comment https://www.classiczcars.com/forums/topic/37094-headlight-lens-repair-question/#findComment-330828 Share on other sites More sharing options...
September 14, 201014 yr comment_330834 x2 on the 3M kit.My son just bought this kit from Wal Mart for about $15 for the lights on his Mitsubishi Eclipse which were very clouded and yellowed. It's just a bunch of sanding pads that get finer and finer, ending with a polishing pad. No liquids or waxes or rubbing compounds or anything like that. You'll need a good drill (corded is best). I was a little skeptical, but his lights came out perfectly clear, it was pretty amazing.Sean. Link to comment https://www.classiczcars.com/forums/topic/37094-headlight-lens-repair-question/#findComment-330834 Share on other sites More sharing options...
September 17, 201014 yr comment_331025 Different lenses respond differently. I've used rubbing compound on my Lexus and they cleaned up pretty well. A friend has tried wet sanding and then polishing his BMW lenses and they still look like crap. Whatever you do, its probably a good idea to keep wax on them after polishing. This not only fills in the small pits, creating a clearer surface, but also retards (can I still say that word?) future oxidation.I had the same results. What I ended up doing was ordering aftermarket headlights from eBay or Automart. The results are far better. Remember! Your time is worth something, don't use it sanding and polishing... Link to comment https://www.classiczcars.com/forums/topic/37094-headlight-lens-repair-question/#findComment-331025 Share on other sites More sharing options...
