Posted September 26, 201014 yr comment_331841 Does have a source they recommend for the rubber grommets? Specifically, I am looking for the large grommet that the cowl drain hose slides through-- Thanks Link to comment https://www.classiczcars.com/forums/topic/37212-cowl-drain-grommet/ Share on other sites More sharing options...
September 27, 201014 yr comment_331852 And you may also want to extend that drain hose OUT from the car.Look in my gallery.E Link to comment https://www.classiczcars.com/forums/topic/37212-cowl-drain-grommet/#findComment-331852 Share on other sites More sharing options...
September 27, 201014 yr Author comment_331856 Good point. I will look into this--and print out some photos. Thanks! Link to comment https://www.classiczcars.com/forums/topic/37212-cowl-drain-grommet/#findComment-331856 Share on other sites More sharing options...
September 27, 201014 yr comment_331874 When I lived in Denver I'd go to Rocket Seals, if they didn't have it they normally could tell me who without giving me bad advice, and one time they stated I don't know ware you can get that, not bad out of 100 visits or so. SO what I'd do is look for a good seal dealer, for the firewall Bonsai Motor works got me all those grommets. Link to comment https://www.classiczcars.com/forums/topic/37212-cowl-drain-grommet/#findComment-331874 Share on other sites More sharing options...
