Posted September 27, 201014 yr comment_331924 Is the pedal box on a 73 240Z automatic transmission car the same as on a manual transmission car? In other words, can I just bolt the 2 pedals from the manual pedal box into the automatic pedal box, attach the springs and stops and bushings and proceed from there? Link to comment https://www.classiczcars.com/forums/topic/37219-73-auto-transmission-pedal-box/ Share on other sites More sharing options...
September 28, 201014 yr comment_331950 10-4Did my 73 two years ago. Just took out the auto brake pedal, and put in the clutch and brake pedals out of another manual box. Super easy! Running the clutch lines is another story.DK Link to comment https://www.classiczcars.com/forums/topic/37219-73-auto-transmission-pedal-box/#findComment-331950 Share on other sites More sharing options...
September 28, 201014 yr Author comment_331966 How about the wires to the auto tranny.......what do you do (which wires do you splice) to complete the starting circuit? Thanks Guy Link to comment https://www.classiczcars.com/forums/topic/37219-73-auto-transmission-pedal-box/#findComment-331966 Share on other sites More sharing options...
September 28, 201014 yr comment_331983 You can find the wiring diagrams for both the automatic and manual transmissions in the 73 FSM. There should only be a couple of circuits that are different between the two.Steve Link to comment https://www.classiczcars.com/forums/topic/37219-73-auto-transmission-pedal-box/#findComment-331983 Share on other sites More sharing options...
October 29, 201014 yr comment_334632 My syncros are dead I can barely get it into 3rd, any suggestion on wheter to rebuild, buy reman, swap a used one, or sell the car? Link to comment https://www.classiczcars.com/forums/topic/37219-73-auto-transmission-pedal-box/#findComment-334632 Share on other sites More sharing options...
