Paint Formulation for 920 Gold
jfa.series1
A member from the NE messaged me about his difficulty in locating a supplier for 920 Gold. I use a local auto paint supplier that is a PPG outlet, this color formulation is in the PPG computer. It is available in the old single stage acrylic enamel as well as the more current two-stage finishes.
Jim
Most licensed shops today can't/wont touch the old single-stage paints due to regulatory issues - way too many VOCs are released. I only mentioned it because it is still available to the DIY'rs.
Your 920 Gold effort is looking outstanding! I hope to see mine back from the paint shop in about a 3 weeks.
Jim
PPG is the ONLY way to go Gold..... I'm quite pleased with the color, the match to the original and the gloss.
The color looks pretty close to me. Mine is just not as glossy even with 4 coats of Zaino show wax. I also wonder if the color has shifted a bit due to 40 years of aging. And then again, the lighting is a factor. So many variables with color.
My painter had the area under the windshield rubber to compare.....the match was amazing. You're right .....lighting makes a big difference.....from picture to picture can vary, but in person the match is exceptional.
Edited by Diseazd
