Rear sway bar
biggels_7
Hewy guys just after some advice i was wondering who here runs a rear sway bar and if so has it made any improvements on the way the car turns it or does it cause more over steer. Ive heard so many conflicting stories from people just would like some more input before i look at going down this track
cheers
Richard
My experience, though limited, shows that a rear bar does increase oversteer a bit. My bar is 3/4" (which may be a bit heavy) and a smaller one might not be as severe. I had originally set the car up for Auto-X back in the '70s and it really helped there, but on track days, it can get a bit squirrelly as the speeds are considerably higher.... makes you pay attention, I'll tell ya!
Two basic theories on sports car suspension:
1. Run soft springs with stiff bars
2. Run stiff springs with soft bar, possibly no rear bar.
The stock Z is set up with very soft springs and no rear bar. If you want it to handle you really need to control the roll, as you lose negative camber with body roll. For a street car, #1 is probably the way to go, so that means bigger front and rear bars, and in all likelihood stiffer springs as well, since the Z was undersprung from the factory.
My 260 has a huge rear bar to go along with the large front bar. A normal aftermarket bar set is 1" F and 3/4" R. My front is 1", but my rear is a bit over 1". The car is neutral, handles very well on the track and is super easy to control at the limit. YMMV.
Hopefully, this isn't too far off of the topic. Are Tokico drop springs with an MSA front sway bar considered stiff enough to fall into option 2?
Option 2 is more for race cars. The Tokico springs are not nearly stiff enough to control roll by themselves, and adding a big front bar with no rear will lead to even more understeer. Nobody says you "have to" do any of this, but if you just want to get Tokico springs I would suggest you either leave the front bar alone or get the aftermarket front and rear bars.
I am not a big fan of the Tokico springs though. Do a search and you'll see lots of people who have the front springs nearly coil bound.
Just to be clear for future searches, only the 240Z Tokicos are progressive and have the issue mentioned. The Tokicos are linear for 280Zs and don't have the stacked dead coil issue.
Well crud, the cars also already had tokico springs on them. There is an autocross in a couple weeks, maybe I will actually get a chance to push it hard then.
I have heard that the coils can bottom out on the highway, but I havent experienced anything bad yet.
