Email logins are now active ×
cylinder heads
Darrell 240Z
Yes to question #1. Question #2 E-31 has 42.5 cc combustion chambers....E88 has 44.7cc combustion chambers. E88 up to 7-73 has the same size valves, then the exhaust valve size was increased to 1.38 inches vs 1.30 inches on E88's before 7-73. The intake valves on both the E31 and E88 were 1.65 inches.
Edited by Diseazd
The early E88 is obviously no problem.....if using the later head with the larger exhaust valve, you should probably eyebrow the block for added clearance and flow if the block isn't overbored. The late 73's have the same bore size as the early Z's ......... not sure if they are eyebrowed from the factory for the larger exhaust valve.
  • Who's Online   1 Member, 0 Anonymous, 257 Guests (See full list)
