Datsun Roadster ones are the same as early 204z...i think?
It is the same bolt pattern but not the same wheel, close though. The wheel covers from a Z "might" work on a Roadster wheel. I can check for sure later. The wheel from a Roadster will have 3 balls welded to the inner ring for the 'baby moons' to snap over. Here is one of each.
Bonzi Lon
I stand corrected. Went out and looked, both are the same except for the Roadster has mounting tabs, (not the balls) for the 'hub caps', the 240Z wheel covers will fit.
Bonzi Lon
Edited by Bonzi Lon
correcting information
