Since my last post, I deciced to go with early SU carbs in my ongoing restoration of my '73 240Z. Yep, we got the '81 280ZX L28 going in next week. Since I'm using a P79 head, I must go with an electric fuel pump. I need to know:
Which pump to get; Brand, psi, and gallons per hour.
And do I simply regulate the line, or do I double regulate right before each carb (leaving the system un-hindered thus avoiding possible vapor lock)?
"Go into emptiness, strike voids, bypass his defences; hit him where he does not expect you" -Lao Tzu
https://www.classiczcars.com/forums/topic/373-su-carb-specs-help/
