Posted October 6, 201014 yr comment_332676 i have a stock 73 240z. i have a chance to buy CHEAP a set of universal fit 17"s rims that have 224/40 tires on them. would these fit and if not , could i go lower say 215/40 or 205/40. how would i be able to tell? Link to comment https://www.classiczcars.com/forums/topic/37305-need-advice/ Share on other sites More sharing options...
October 6, 201014 yr comment_332684 We need to know the width and offset of the 17s to be able to give you an answer. By universal, you mean 4x100 and 4x114.3 right? It's not a 5-lug universal right?The original diameter of our tires are ~25". If you keep the overall diameter between 24 and 25", your speedometer will stay close to accurate. A 215/45 or 225/40 would get you close but 225/40 is not a common size. A 225/45 will be close as well and that is a common size tire. If it is 225/50/17, that is probably too tall at nearly 26 inches. I suggest playing around on tirerack with different tire sizes and checking specs. Link to comment https://www.classiczcars.com/forums/topic/37305-need-advice/#findComment-332684 Share on other sites More sharing options...
October 6, 201014 yr Author comment_332688 i don"t know width or offset. i found the sle on craigslist. they are four lugs. thanks for the advice, i think i'll go take a look at them. they are only 200 bucks. Link to comment https://www.classiczcars.com/forums/topic/37305-need-advice/#findComment-332688 Share on other sites More sharing options...
October 6, 201014 yr comment_332712 you get what you pay for..end thread. Link to comment https://www.classiczcars.com/forums/topic/37305-need-advice/#findComment-332712 Share on other sites More sharing options...
October 6, 201014 yr comment_332716 Here is a tire size calculator. I believe the original size was 195 70 14 (someone here will correct if I'm wrong). This calculator will show you how to get to the same diameter/circumfrence. This will NOT account for width or offset.http://www.miata.net/garage/tirecalc.html Edited October 6, 201014 yr by tlorber Link to comment https://www.classiczcars.com/forums/topic/37305-need-advice/#findComment-332716 Share on other sites More sharing options...
