need advice
hotscrub
We need to know the width and offset of the 17s to be able to give you an answer. By universal, you mean 4x100 and 4x114.3 right? It's not a 5-lug universal right?
The original diameter of our tires are ~25". If you keep the overall diameter between 24 and 25", your speedometer will stay close to accurate. A 215/45 or 225/40 would get you close but 225/40 is not a common size. A 225/45 will be close as well and that is a common size tire. If it is 225/50/17, that is probably too tall at nearly 26 inches. I suggest playing around on tirerack with different tire sizes and checking specs.
