November 17, 201014 yr comment_336268 Here's an article with some Rear alignment data and modifications. Look at article 87 & 88. I had custom Vertical Brace plates that the Transverse bracket mounts to help correct a Rear Toe problem. http://www.classiczcars.com/forums/showthread.php?t=33630&page=4&highlight=alignmentAs Jon says, your rear Toe data is pretty good as is the camber. Any total toe-in on the rear of less than 0.50 is good and as long as it's split 50/50 between each side to assure it tracks straight - I'd leave it alone.Good luck and happy driving. Link to comment https://www.classiczcars.com/forums/topic/37317-wheel-alignment/?&page=2#findComment-336268 Share on other sites More sharing options...
August 30, 201212 yr comment_400266 I'm having a similar issue, and I'm not sure where to begin. I just bought the 71 240, and I took it in to be aligned. They adjusted the toe on the front, but that's it. My right rear tire needs to move 2.5 degrees to be vertical, and my left rear tire needs to move 1.5 degrees. The front tires are close enough that a camber kit (good for 1.5 degrees) would work....any suggestions?I do know that the car has been lowered, but I'm not sure by how much (or what springs the seller put in). Also, it has 16" rims. I'm thinking maybe taller springs would help get the rear wheels pushed out enough for a camber kit to help?The specs are:Left front:Camber: -.06Caster: 2.9Toe: .13Right front:Camber: -.3Caster: 3.7Toe: .11Left rear:Camber: -1.2Toe: -.10Right rear:Camber: -2.0Toe: .20Suggestions are MUCH appreciated! Link to comment https://www.classiczcars.com/forums/topic/37317-wheel-alignment/?&page=2#findComment-400266 Share on other sites More sharing options...
