Posted October 8, 201014 yr comment_332864 hi i just got 2 top draft webers 32/36dgev put them on but have aproblem starting and i think im missing carb linkage if any body know any thing about this or have picters please help Link to comment https://www.classiczcars.com/forums/topic/37326-carbs-3236-weber-dgev-problem-help/ Share on other sites More sharing options...
October 8, 201014 yr comment_332933 Those are the same carbs that came on my sons car=260z I noticed that after they sit for a couple weeks they seem to dry out and it takes several seconds of cranking the engine over and pumping the gas to get it primed up again. Then it starts great. They are coldblooded but as long as I start it every week it fires right up. I found an online tutorial for tuning them by googling the letters/numbers. I'd put a link but it is on a different computer. Link to comment https://www.classiczcars.com/forums/topic/37326-carbs-3236-weber-dgev-problem-help/#findComment-332933 Share on other sites More sharing options...
October 16, 201014 yr Author comment_333586 hi if you can please take a couple picters of carb linkege to the fire wall im just not to shure if i got all linkege so if any bady have any picters of dual weber carb 32/36dgev please sendem to me from manifold to the carbs, to the fire wall or any please i will be very thanksfull Link to comment https://www.classiczcars.com/forums/topic/37326-carbs-3236-weber-dgev-problem-help/#findComment-333586 Share on other sites More sharing options...
October 17, 201014 yr comment_333633 This is not too good a pic. I will take another of the firewall tomorrow. Link to comment https://www.classiczcars.com/forums/topic/37326-carbs-3236-weber-dgev-problem-help/#findComment-333633 Share on other sites More sharing options...
