Email logins are now active ×
rear end noise
manny1973
I'm getting a rumbling grinding noise from the drivers side rear end. I thought it might be rear wheel bearings so I put in new ones. Car is back together and the noise is still there. I think it is coming from the differential..
My car is a stock 72 Z. Any thoughts on repairing. Is it difficult to change the rear end? I have changed the fuild and it did not make a difference.
Manny when you drained the fluid was there much metal filings on the drain plug magnet? Is there much play when you manually move the car back and forth?
If you lift the rear of the car and support in on stands and start the engine and put it is first gear at idle . Can you hear the noise .
BE SURE YOU BLOCK THE FRONT WHEELS. And DON'T rev the engine in gear, just let the engine idle. You don't want to launch your car off the stands.
If the diff is bad locate another rather than having your rebuilt. If your Z is a manual car it has 3.36 to 1 gearing if an automatic car then 3.54s.
Gary
  • 1 month later...
Some claim to be able to check U-joints in the car, I never could. I have to take the halfshafts out to get a good idea on the U-joints.
Swapping the diff is pretty easy. There's no big mystery there, just disconnect the shafts and mounts and pull it out and reverse procedure for the new one.
