Posted October 11, 201014 yr comment_333162 Hey guys,Does anyone know where I can buy the following:1.The three heat/vent control cables2. The hose from the air cleaner to the valve cover (5/8 ID I think) Would this hose need to be a gas/oil grade?3. A series 1 radio, doesnt matter if it's working or not, I just want to keep the correct look on the inside. If anyone can help me out let me know.Thanks,Randy Link to comment https://www.classiczcars.com/forums/topic/37359-i-need-the-following-to-finish-my-240help/ Share on other sites More sharing options...
October 11, 201014 yr comment_333170 I have a radio You can PM me. Manny Link to comment https://www.classiczcars.com/forums/topic/37359-i-need-the-following-to-finish-my-240help/#findComment-333170 Share on other sites More sharing options...
October 12, 201014 yr Author comment_333257 Found the cables, but still need the hose and a series 1 radio......Anyone? Link to comment https://www.classiczcars.com/forums/topic/37359-i-need-the-following-to-finish-my-240help/#findComment-333257 Share on other sites More sharing options...
October 12, 201014 yr comment_333259 The hose definitely does need to be fuel/oil rated. I've seen heater hose practically dissolve in this application. The last one I bought was from Nissan, but I've since heard they are NLA. The factory hose had/has some sort of bottle-brush looking strainer inside it, but I really doubt that is necessary. I've been told that NAPA stores often have a decent selection of bulk oil-rated hose in various sizes. Edited October 12, 201014 yr by Arne Link to comment https://www.classiczcars.com/forums/topic/37359-i-need-the-following-to-finish-my-240help/#findComment-333259 Share on other sites More sharing options...
October 12, 201014 yr Author comment_333268 Thanks Arne,I'll try NAPA, everywhere else I have looked doesn't carry a oil/gas rated hose in that large of a diameter. Link to comment https://www.classiczcars.com/forums/topic/37359-i-need-the-following-to-finish-my-240help/#findComment-333268 Share on other sites More sharing options...
October 12, 201014 yr comment_333269 Arne said: The hose definitely does need to be fuel/oil rated. I've seen heater hose practically dissolve in this application. The last one I bought was from Nissan, but I've since heard they are NLA. The factory hose had/has some sort of bottle-brush looking strainer inside it, but I really doubt that is necessary. I've been told that NAPA stores often have a decent selection of bulk oil-rated hose in various sizes.Arne, that brass bottle-brush thing is, I believe, called a flame arrestor, and it may still be available from Nissan. Worth a shot.Dan Link to comment https://www.classiczcars.com/forums/topic/37359-i-need-the-following-to-finish-my-240help/#findComment-333269 Share on other sites More sharing options...
October 12, 201014 yr comment_333271 mally002 said: Thanks Arne,I'll try NAPA, everywhere else I have looked doesn't carry a oil/gas rated hose in that large of a diameter.mally002, I had trouble finding that same fuel rated 5/8 inch inner diameter hose a few months ago as I wanted to replace the hose on the gas tank that is all the way in the back of the tank that goes to the filler hose. I couldn't find it here at NAPA or at Shuck's auto supply but found a fuel rated multipurpose rubber hose that is 5/8 inch inner diameter at Andy's supply in Boise at (208) 344-3568. They told me they will sell the hose by phone order, this info added later.Mike edit: I just noticed someone is selling 5/8 inner diameter marine hose on ebay by the foot, it may be fuel rated. Edited October 13, 201014 yr by Mikes Z car Link to comment https://www.classiczcars.com/forums/topic/37359-i-need-the-following-to-finish-my-240help/#findComment-333271 Share on other sites More sharing options...
October 12, 201014 yr Author comment_333275 Thanks Mike, that would be great. Link to comment https://www.classiczcars.com/forums/topic/37359-i-need-the-following-to-finish-my-240help/#findComment-333275 Share on other sites More sharing options...
October 12, 201014 yr Author comment_333285 FYI......I found some hose today at NAPA.It is fuel/oil rated and 5/8 ID. My receipt says the part is NBH H-183. I went ahead and got 5 feet of hose, cost was $7.59I won't be winning any concours events, but thats ok with me. Link to comment https://www.classiczcars.com/forums/topic/37359-i-need-the-following-to-finish-my-240help/#findComment-333285 Share on other sites More sharing options...
October 13, 201014 yr comment_333328 I found fuel rated hose that size (and others) at my local John Deere dealership, rated to 300psi too. Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/37359-i-need-the-following-to-finish-my-240help/#findComment-333328 Share on other sites More sharing options...
October 13, 201014 yr comment_333329 I used to get mine at ACE Hardware when I worked there. Link to comment https://www.classiczcars.com/forums/topic/37359-i-need-the-following-to-finish-my-240help/#findComment-333329 Share on other sites More sharing options...
