Posted October 11, 201014 yr comment_333164 hello i have the same problem as posted by another member, it sounds exactly the same, but another member told me my solution is probably different because mine is not fuel injected,i drive the car and when i go about 40, the car just shuts off, like someone just turned the key on me, the car will fire right back up when i go to re start it, as if nothing happened, then it will happen again. Link to comment https://www.classiczcars.com/forums/topic/37360-73-240z-shuts-off-while-driving/ Share on other sites More sharing options...
October 11, 201014 yr comment_333167 I had the same problem once.....It was a loose connection on the coil. Take a pair of needle nose pliers and squeeze all the female connectors on the coil so they slide on snugly. See if that helps. Link to comment https://www.classiczcars.com/forums/topic/37360-73-240z-shuts-off-while-driving/#findComment-333167 Share on other sites More sharing options...
October 12, 201014 yr comment_333198 i had a loose connection at the coil, or bad ballast resistor that would do that long ago. Link to comment https://www.classiczcars.com/forums/topic/37360-73-240z-shuts-off-while-driving/#findComment-333198 Share on other sites More sharing options...
October 12, 201014 yr comment_333202 This could either be a clogged fuel filter... OR as others mentioned a loose connection in the ignition system. Link to comment https://www.classiczcars.com/forums/topic/37360-73-240z-shuts-off-while-driving/#findComment-333202 Share on other sites More sharing options...
October 12, 201014 yr Author comment_333267 i just placed a new filter in, before i drove it, so i don't think it could be clogged, but i'll check,its crazy cause prior to this i had had starting problems, and people where saying to see if the fuel filter was clogged, and after looking and looking for it, i noticed the previous owner took out the fuel filter and ran a hose from the tank straight to the fuel pump...now based on my hanse manual, it looks like im suppose to have the hose that goes from the fuel tank, to the filter, then from the filter to the fuel pump...just wondering does that sound right? Link to comment https://www.classiczcars.com/forums/topic/37360-73-240z-shuts-off-while-driving/#findComment-333267 Share on other sites More sharing options...
October 13, 201014 yr comment_333327 Yes it does. The fuel from the tank goes into a see through filter, then to the fuel pump, to the carb inlets. Inside each carb inlet lid should be a brass filter. Remove the fuel inlet bolt on the carb lid, remove brass filter and clean it. This is for SU carbs.Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/37360-73-240z-shuts-off-while-driving/#findComment-333327 Share on other sites More sharing options...
October 13, 201014 yr Author comment_333333 THANK YOU very much i will try that,but i was wondering does it matter on how the filter is mounted or sitting?what i mean is that the filter came with small fuel hose, and i have that fuel hose going from the tank to the bottom of the filter, but cause its so small the filter sits sideways, and then the hose from the top of the filter to the pump.should that matter that it sits sideways Link to comment https://www.classiczcars.com/forums/topic/37360-73-240z-shuts-off-while-driving/#findComment-333333 Share on other sites More sharing options...
October 13, 201014 yr comment_333337 should that matter that it sits sidewaysIndeed it could. The fuel line down stream must be "wet" (inlet above the outlet), otherwise fuel flow will be interrupted and the engine will cease to run. Edited October 13, 201014 yr by Gary in NJ Link to comment https://www.classiczcars.com/forums/topic/37360-73-240z-shuts-off-while-driving/#findComment-333337 Share on other sites More sharing options...
October 13, 201014 yr comment_333353 Does the car still have both fuel pumps(electric by the tank and mechanical on engine)?The electric pump has a filter inside if it is stock. Link to comment https://www.classiczcars.com/forums/topic/37360-73-240z-shuts-off-while-driving/#findComment-333353 Share on other sites More sharing options...
October 13, 201014 yr Author comment_333354 ok, so i just want to make sure i connect it correctly after getting a longer fuel hose,it should go from the tank, to the top of the fuel filter, then a hose from the bottom of the fuel filter to the fuel pump..and i should make sure the filter sits up right...thank you Link to comment https://www.classiczcars.com/forums/topic/37360-73-240z-shuts-off-while-driving/#findComment-333354 Share on other sites More sharing options...
October 13, 201014 yr comment_333357 The filter should have an arrow showing the flow. If a stock filter in the engine compartment, then it should connect at the bottom which has a straight nipple. The "top" goes at a right angle to the fuel pump. Link to comment https://www.classiczcars.com/forums/topic/37360-73-240z-shuts-off-while-driving/#findComment-333357 Share on other sites More sharing options...
October 13, 201014 yr Author comment_333358 @ darrel, wow i did not know there was a filter inside of the pump, everytime i read through manuals it kept saying that i should be able to see through the casing to see the filter inside, and then with a diagram from my manual it showed that there should be a filter by the tank, and when i purchased the car there was no filter by the tank.i do have a fuel pump by the tank, i didn't know there was another on the engine, can you tell me specifically where to look, and what it should look likeim pretty sure the fuel pump by the tank is still stock, it looks aged, so would i have to replace the whole fuel pump or should i be able to remove the fuel pump, and replace just the filter?Sorry for all the questions everybody...thanks again for your guys' help!thank you Link to comment https://www.classiczcars.com/forums/topic/37360-73-240z-shuts-off-while-driving/#findComment-333358 Share on other sites More sharing options...
