Posted October 17, 201014 yr comment_333648 Does anyone know a replacement part number for the 5 watt push in map lamp? The service manuels that I have don't give an old number to cross reference it to.Thanks! Link to comment https://www.classiczcars.com/forums/topic/37414-1978-280z-map-lamp-replacement/ Share on other sites More sharing options...
October 17, 201014 yr comment_333658 Are you referring to the cabin light on the roof behind the seats (dome/cabin lamp) or the lamp above the vents on the dash (map light)? AFAIK, You can get new replacement cabin lamp units, but not the map light. There are also L.E.D. inserts for the cabin lamp that is supposed to give more light, but I haven't heard of any kind of improvements for the map lamp. About all you can do is make sure you have good electrical connections with clean contacts everywhere. I use DeOxit 100 for the latter. Link to comment https://www.classiczcars.com/forums/topic/37414-1978-280z-map-lamp-replacement/#findComment-333658 Share on other sites More sharing options...
October 17, 201014 yr comment_333668 This url might help some if it's the map light...http://www.carpartsmanual.com/datsunS30/DatsunFairladyZIndex/Electrical/StepMapLamp/tabid/1684/Default.aspxand this one if it's the overhead lamp...http://www.carpartsmanual.com/datsunS30/DatsunFairladyZIndex/Electrical/StepMapLamp/tabid/1684/Default.aspxwebdawg1 Edited October 17, 201014 yr by webdawg1 Link to comment https://www.classiczcars.com/forums/topic/37414-1978-280z-map-lamp-replacement/#findComment-333668 Share on other sites More sharing options...
October 17, 201014 yr comment_333677 Is the Step Lamp the one that goes in the door? Link to comment https://www.classiczcars.com/forums/topic/37414-1978-280z-map-lamp-replacement/#findComment-333677 Share on other sites More sharing options...
October 17, 201014 yr comment_333696 If I were you, I'd replace the lamp with an LED lamp anyway. Same with the dome light. The map light switch can wear very badly and heat, causing the plastic to deform. Link to comment https://www.classiczcars.com/forums/topic/37414-1978-280z-map-lamp-replacement/#findComment-333696 Share on other sites More sharing options...
October 18, 201014 yr comment_333703 Where do you get a map lamp with L.E.D.s in it? Link to comment https://www.classiczcars.com/forums/topic/37414-1978-280z-map-lamp-replacement/#findComment-333703 Share on other sites More sharing options...
October 18, 201014 yr comment_333728 They make LED bulbs that will fit in place of the bulb that's in the map light. Had one in my 78. If I'm not mistaken, all the OP wants to know is the number of the bulb that's in the map light. If that's the case, its a 158. Edited October 18, 201014 yr by sblake01 Link to comment https://www.classiczcars.com/forums/topic/37414-1978-280z-map-lamp-replacement/#findComment-333728 Share on other sites More sharing options...
October 19, 201014 yr Author comment_333820 Thanks alot guys! Link to comment https://www.classiczcars.com/forums/topic/37414-1978-280z-map-lamp-replacement/#findComment-333820 Share on other sites More sharing options...
October 21, 201014 yr comment_333995 If you do try an L.E.D. in the map lamp, please let us know how well it works. Link to comment https://www.classiczcars.com/forums/topic/37414-1978-280z-map-lamp-replacement/#findComment-333995 Share on other sites More sharing options...
October 21, 201014 yr comment_334004 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Edited October 21, 201014 yr by sblake01 Off topic (as usual) Link to comment https://www.classiczcars.com/forums/topic/37414-1978-280z-map-lamp-replacement/#findComment-334004 Share on other sites More sharing options...
