1978 280Z map lamp replacement
dankfrye@charter.net
Are you referring to the cabin light on the roof behind the seats (dome/cabin lamp) or the lamp above the vents on the dash (map light)?
AFAIK, You can get new replacement cabin lamp units, but not the map light. There are also L.E.D. inserts for the cabin lamp that is supposed to give more light, but I haven't heard of any kind of improvements for the map lamp. About all you can do is make sure you have good electrical connections with clean contacts everywhere. I use DeOxit 100 for the latter.
They make LED bulbs that will fit in place of the bulb that's in the map light. Had one in my 78. If I'm not mistaken, all the OP wants to know is the number of the bulb that's in the map light. If that's the case, its a 158.
Edited by sblake01
  • Who's Online   1 Member, 0 Anonymous, 563 Guests (See full list)
