Hey, I was looking for a new rear setup for my datsun, since my springs and shocks need reaplaced before long anyways. I found this setup, from Comp Eng. on the Advance Autoparts website, part number C2051, for $235. Is this a descent setup? Are there any others available that I should be looking at? What do you think about this? Thanks!
The problem with the part from Advance Auto is that it is made to weld to a solid rear axle at the bottom.
You can get performance inserts and springs from MSA that are straight bolt ons. If you want to do some modifying (cutting/welding) you can contact Ground Control and get their coil-over setup. $$$$
Here's the link to the Advance Auto enter the part number C2051 into the item box...
